NinerBikes wrote:
10 amps is plenty with that 160 watt set of panels. It starts out at 22V and gets down to 18V in the specs, and is capable of putting out 8.88 amps,max, if the battery will even allow that kind of charge take......
Niner the Isc on that is 9.46a which he should get with the panels pointed at a high sun. You are using the Imp figure which is meaningless with PWM.
10 amps on two 6s is 5 amps per battery, which is the acceptance rate for about 90% SOC at 14.5v. So there should be no trouble finding time from 50-90 SOC for the battery bank to accept the 9.46a
Also after 90% and amps taper, you can run things that take from the solar--any amps over what the battery is taking up to what the panel can do at the time.
Eg, good time to recharge/use the laptop late afternoon while the panel can still do 9a when pointed, batts taking 3 amps, inverter with laptop load taking 6 amps
http://www.solarblvd.com/Solar-Panels-&-Systems-12-Volt-Solar-Panels/c1_269/p2754/W-Solar-160-Watt-Foldable-12-Volt-Solar-Panel/product_info.html
