OregonTRX4
Feb 16, 2014Explorer
Solar voltage help...
I just connected my solar kit (160w cmp12 controller)and the voltage while connected to the rv batteries reads 16.55v. Is this normal or too high? Sorry but im new to this.
BFL13 wrote:
Niner,
..." My unit at 120 watts is 3/4 the output that his is. I have seen, at most, 6.62 amps out of mine,on the charge/load side, measured by one of those RC battery charge meters with 4 readings on the screen."
When I had a 120w panel, its Isc was 7.6a and sure enough that's what I got at the batteries as seen on the Trimetric. You need to aim the panel at a high enough sun, disconnect the controller, and take the Voc and Isc on the panel's wires using a multimeter. It is under 10a so that will not fry the meter in amps setting.
You then hook it all back up and see what the amps is at the battery. If not close to the Isc you got, you have wiring issues
