- mike-sExplorer
starcraft69 wrote:
It goes the same place the as the power in a disconnected battery.
I am curious what happens to the watts /volts when your system is fully charged and you have no demand? Were does the extra power go? - Itinerant1ExplorerDepends on the size of system or your excess potential power generated. Is it enough for your hot water or fridge or just a tv/ radio?
- BFL13Explorer II
starcraft69 wrote:
I am curious what happens to the watts /volts when your system is fully charged and you have no demand? Were does the extra power go? Is there a way to use it for Hot water, Ect.?
Yes, but then you end up with a bunch of hot water just before dark, and the water gets cold overnight, so it is no good for your morning shave, etc.
They do have a special element thing that you can use with your hot water tank for that. - 2oldmanExplorer II
starcraft69 wrote:
Hot water? That takes a lot of power, way more than any solar excess. As for where it goes, I have no idea.
Were (sic) does the extra power go? Is there a way to use it for Hot water, Ect.? (sic) - Johno02ExplorerIt just reflects back up and causes global warming and hurricanes. Thats why solar panels have to be grounded, so the extra can flow into the earth without warming the air.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
