towpro's avatar
towpro
solar wiring question
first off I am Using the Bogart Engineering gear.
What is your opinion between using a fuse vs a circuit breaker (12V breakers) on the solar line as well as the battery line?
I am only buying 200w of solar. Charger is rated for 30A. Do I use 30A fuses (or breakers) or would you use 15A (which is more than I expect the panels to put out).
What about disconnects? Do I need one on both sides of the solar charger? why?
Can I use a double pole switch to open both sides at the same time or do I want Two single pole switches? Can an inline fuse be considered a disconnect?
Thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
