1L243's avatar
1L243
Explorer II
Oct 10, 2021
Solar Wiring Question
When I installed my 500 watt panel, 2000 watt inverter, 340ah solar system it was a learning process. I have a 35 foot bumper pull Toy Hauler. My four 12 volt deep cycle batteries are on the trailer A frame which was designed as a generator rack. My inverter, charge controller fuses and switches are installed in the pass through storage just behind the battery bank.
I ran 4.0 wire from the inverter to the the batteries. My plan at initial install was to install positive and negative Buss bars in the battery box. along with the battery monitor shunt. After I installed all the wires reality set in that I did not have room for the buss bars, so I elected not to put them in. This meant that the the main pos/neg battery terminals and load side of the shunt got very crowded.
I used the system this way this season when dry camping for two weeks all worked as it should.
But when I got home I decided to rip all the wiring out of the battery box and rewire with the pos/neg buss bars and shunt moved into the storage area with the inverter and charge controller. It also allowed me to install a breaker protected fuse block for all the peripheral add on I have installed.
Now after a very long update my question.
My 4.0 inverter cable runs from the inverter to the battery through the buss bars BUT my chassis ground which runs from the frame of the trailer to the neg buss bar is only 2AWG. Should the chassis ground be 4.0 wire ?
Having RV issues? Connect with others who have been in your shoes.24,238 PostsLatest Activity: Apr 24, 2025
