Jonnygsx's avatar
Jonnygsx
Solar wiring question
Looking to install solar on my prowler 24lz trailer. Watching and reading peoples installations it seems that the best thing is to install your charge controller near your battery and then wire directly to the battery. However on my trailer the best location for my panel is on the rear, so running wires all the way to the front where my batteries are will be a bit of a challenge. I did see a few instances where the controller was wired into the wiring for the converter. Is this an acceptable option? Will there be a greater volt loss by doing this method vs having the controller near the batteries with a short run of power wire to the batts?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 10, 2026
