pianotuna
Feb 22, 2014Nomad III
Hi MiRV,
No, solar panels can not power the existing converter.
Yes, you can add an inverter to have 120 volt power available without shore power or a generator.
What size is the battery bank in amp-hours?
MiRV wrote:
I'm looking at installing a portable (to start) solar solutions with about 200W on the RV and would like to know if I can setup the solar to connect to the converter/charger installed in the RV.
I upgraded my Magnetek 6345 last summer when the system had some issues. The NEW 6345 uses a 3 stage charger (much like those in a Solar Controller). Therefore, to save money on the initial configuration, I'd like to wire the solar panels into the converter/charger to charge the batteries vs running the generator.
Additionally, I'd like to add an inverter (2000) so that I can run other AC appliances…but I'm not sure on the charging/configuration for this.
Is this possible to use the converter/charger and then install an larger inverter for the DC to AC? And if so, how do you do it?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
