Snowman9000
Jan 02, 2016Explorer
grizzzman wrote:Snowman9000 wrote:
I've been reviewing the archives. So the Solar30 is adjustable for charging voltage. From BFL13's posts, I think what I get is that it is a taper charger, and they take liberties with the term "float". It puts full amps to the battery until Vabs is reached. Then it does what?
Shuts off?
Floats at a lower voltage?
Continues tapering at Vabs?
I get the impression it shuts off.
Yes it shuts off (At a voltage you select) then it turns back on (At a voltage you select) As an example you could set it at 14.8 volts then set it to turn back on at 13.4 volts.
Make NO mistake this is a cheap and inefficient solar charge controller. As an example, if you dont understand that it would need to be turned down durring non use times, it will eventually overcharge your batteries.
Good luck with your adventures
In reading that manual, I can't see any setting for it to turn back on. There is the one setting for stopping charging. But the other settings apply to turning the LOAD on and off. I *think* BFL has written that you have to disconnect the pv source to get it to restart charging at whatever charging voltage you have set.
I am just looking for something to have on hand as a cheap backup. If it doesn't continue to charge after hitting the desired voltage, that seems goofy.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
