red31
Jan 02, 2016Explorer
re-start?
'Solar30, "float" and "stop charging" is the same one setting, so you have to change the voltage from the higher stop charging you pick (which it then stays at forever till dark) to a lower setting if you want to float lower (such as for just battery maintenance) '
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
