Almot
Jan 03, 2016Explorer III
Snowman9000 wrote:
We need clarification on what has to happen to make it re-start charging.
No, we don't :).
It's written in the manual - when voltage that you've set is reached (they call it the voltage of ceasing charging) - it shuts down. When the voltage drops below this setpoint, it starts charging again. So it will go on and off trying to keep it around this setpoint.
OK for short-term storage if main controller failed and until you get a proper controller. It will maintain Float only, while it would've been nice to hit the Absorption briefly once a day. You don't want to leave it in Absorption while in storage, obviously.
A bit of pain for daily camping unless you like watching it and making changes. You attend to it a few times a day - making sure it goes to 14, then wind you kitchen timer up to 30-60 minutes, then switch to 13, then in the evening you have to remember to switch up to 14 again.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
