BFL13's avatar
BFL13
Explorer II
Mar 03, 2014
Solar30 Controller Test Update
Update 5 March
I just got this and will not have a chance till April to test out what its charging profile is or even if shunt or series, but I was able to power it up and find out the mystery number--how high can you set the high set point? Answer- 15.0 volts
I got this so I could match the voltage I set on another controller where both are on the same battery bank (long story)
The next mystery is what happens after it gets to the set-point? Manual just says it shuts off the PV and then it all gets going again after voltage falls (sounds like a shunt type) Can't find a float voltage setting like it says it has-adjustable it says--oh well, we'll see.
I was hoping it has an adjustable float voltage so I could make that 14.8v too and then it would just stay at 14.8 once it got there till it gets dark, but that might not be possible. At least I can set it to 14.8 as the high.
This thing is huge compared with the "RJ special" I have (CMT02 whatever it's called)--which I did get to try out last year and it works fine except of course it is not MPPT as marked, just PWM, but it maxes at 14.4v and I want 14.8
This one has nice big wire terminals too, takes #8 easy. The terminal screws work backwards though--counter-clockwise tightens the terminal onto the wire :)
I got it from a different ebay guy than this one, but this is the unit
http://www.ebay.ca/itm/30A-Solar-Panel-Charge-Controller-Regulator-SOLAR30-30A-12V-24V-AUTO-360W-720W-A-/181306473974?pt=LH_DefaultDomain_0&hash=item2a36b53df6
Another thing that is great about this, is the AH counter on it. Last year with a split battery bank and one controller on each bank, I could only have the Trimetric on one bank. So I could use this controller on the other and have an AH count of what goes in. (No use like the Trimetric is for counting AH out of the battery though)
  • BFL13 wrote:
    BTW there is a Youtube that Russian guy uploaded I linked some time ago that shows how to push the buttons. Came up on Google..
    Is that the one that shows my clothesline? I was hoping he Photoshop'd that out by now.
  • Niner it is all your fault I got this thing! :) The manual says in one place it has an adjustable high set point and in another that it has an adjustable float voltage. In real life, it seems there is only the one adjustable voltage for when it stops charging (high set point)
    http://www.chinasolarregulator.com/user-manual/solar30.pdf
    Whatever, I am not sorry I got this. I don't even care if it is shunt instead of series. I had a shunt one before and it did the job just fine. You can way over-do the fancy stuff in this racket.
    https://www.youtube.com/watch?v=EOw-ZxYJJ2Q
    He also has the RJ special so you can see how big the Solar 30 is.
  • What do the instructions say for setting the float voltage? There should be something in there about it after setting the bulk charge voltage. Hold the button for 5 seconds or 10 seconds to get it into the next "mode" of adjusting the settings.
    If 14.4 is the bulk voltage default setting, I'd think they would give you + or - .9V as settings?
    Just ordered one, so I blew $31 to be a guinea pig for all of us. Plenty of sunshine here in So Cal to figure it out.
  • Most of the settings are to do with loads. Nothing to do with actual battery charging.
    After we get to our seasonal in mid- April, I will be able to try out this one and the Eco-Worthy MPPT too I haven't used yet. (Although JiminDenver has already reported on that one working ok)
    I just need a simple PWM to run the 130w panel while the Eco-W runs the 230w panel in MPPT. If I stay with a combined bank, then both need to be on it at the same voltage at least up to 14.8. After that amps taper and batteries will be nearly full and the 130w panel will be superfluous since by then the 230w could do it all.
    Based on past years, I will soon wish I didn't even have the 130 :( Maybe I can sell it to some newbie in July after I get some more use out of it in cloudier April-June :)
  • And all for $31 shipping included. I can not see trusting hundreds of dollars to a cheap single stage converter. the 10.5V cut is at 0% SOC (I am unsure as to what that refers to). Do some testing, I will be interested in the AH setting.
