flyfishing48's avatar
flyfishing48
Solar/Inverter Question
Long time RVer, new solar user.
Just bought a new fifth wheel that came with solar. Equipment is:
One solar panel that I think is around 170 watts, a Zamp Solar Charge 30 amp Controller, a Xantrex X2000 Inverter. I should add we have a pair for 6 volt 235 AH Deep Cycle (Crown) Batteries.
Just did 3 nights dry camping, despite being in AZ, it was light overcast for the 3 days. System seems marginal under these conditions for using some lights, water pump for normal stuff, ran the furnace one morning for a few minutes and ran the coffee pot each morning. I did notice the solar panel is dirty from a desert shower on the previous trip. So that didn't help the cause I am sure.
I am not getting my mind around how to run the inverter. Mostly confused about what mode use, Auto On, standby, power save ?
Keystone mounted the inverter off the floor joist in the basement, so not to accessible for use. I will be getting the remote for it.
But I would love to hear from some experienced user about how to best use this system.
  • The minimum is one solar watt per battery amp hour. This is a very common issue leading to “my solar didn’t recharge my batteries...it doesn’t work!” You need at least 65 more watts. I’m 240 amps with 300 solar watts.
