mlts22's avatar
mlts22
Explorer II
Sep 02, 2014
Soldering in lugs?
I saw an interesting way to handle battery lugs (the ones that are sealed:
1: Put heat shrink tubing on, move it well away from where the action is going to take place.
2: Pour molten solder into the lug, keep the lug heated.
3: Shove wires in, crimp. Let cool.
4: Move heat shrink tube back into place, heat that to seal the connection.
I've never tried this, but other than the fact that the lug has to be kept heated during the crimping process, would this be workable? The advantage of this is that the solder would help prevent oxidation.
  • Maybe an important point folks overlook is a tiny pencil torch for lugs up to 4 gauge and a mini torch for larger lugs.
    Filling the lug does not work for me. I use 60/40 solder and paste flux. Flux the heck out of everything. Crimp lug to wire. Clamp terminal vertical (just an itty bitty piece of the terminal tip) in a vise or vise grips. Heat the terminal. This can take MINUTES be patient. When the visible dab of paste solder starts to bubble and melt get ready.
    Feed a bit of solder between the lug and wire
    If it makes a bubble, stop. Keep heating more. Watch the bubble.
    When the bubble melts and flows the terminal IS NOT QUITE READY. Patience.
    The terminal body will heat up before the copper wire does. So the solder bubble will melt vut if you start feeding solder now it will back up and overflow.
    Feed -just enough solder to fill the terminal with a glob, keep heating and watch the glob. After a bit the wire gets hot enough to melt the solder. It instantly sucks the solder blob into the wire strands.
    Start feeding solder. On a large terminal it will suck solder faster than you can feed it. Don't keep playing the flame on the joint, move it away now and then.
    Finally! The joint fills up. The flux floating on top will overflow and then catch fire. Blow it out. You're finished...
  • RoyB's avatar
    RoyB
    Explorer II
    There is a special 'art' when soldering connections that only a select few will master that over the years. I think will stick with my inexpensive $60 8-ton hand crimper. I know that always works for me...
    After all is properly crimped in place then I too will add adhesive type heat shrink tubing to cover all of the open connections and seal-up from weather conditions.
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
