da_bees
May 24, 2013Explorer
I have a Schumacher charger that I thought was going bad because charge rate jumps up and down. Noticed a spark from postive clamp handle and on closer inspection,the cripmed connection is bad. No corosion,no broken wires and no crack in crimp but gentely moving the handle or wire causes continuity to come and go. Who should know crimping technique better than Schumacher? I say crimp it then solder it. I believe corosion at soldered joints are the result of wrong flux,filler and/or failure to clean flux residue from completed joint.
