Jagtech
May 25, 2013Explorer
If you are really anal about the difference, take a GOOD digital multimeter and measure the voltage drop across a crimped connection vs a soldered connection, under heavy load. You will notice a fairly significant voltage drop (millivolts) across most crimps, and no drop across a soldered connection. That said, it likely wouldn't make any difference in the OP's solar connections, where crimps would be fine.
