camperpaul
Jul 17, 2013Explorer
Jagtech wrote:
First of all, on old wire, its best to scrape the wire to remove any corrosion or oxidation. Then use a flux-cored solder (not acid core) for best results.
This works only on solid wire. With stranded wire you would have to remove the corrosion from each individual strand, a very labor intensive endeavor.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
