- Canadian_RainbiExplorer
MEXICOWANDERER wrote:
Can you tell old triceratops here when they changed the name from "Western Union Splice" to "Lineman's Splice"?
I learned the phrase as "Linesman's splice". When I Googled it looking for a picture, I found several references to both Western Union and Linesman's splice for the same thing. - RandACampinExplorer II
Canadian Rainbirds wrote:
Soldering done correctly will have a good mechanical connection first even if it is just a linesman's splice. Then use heatshrink to weather proof it. Don't forget to slide the tubing over one of the wires first. Don't ask me how I know that. :S
I have had wire antennas up in
the air for almost 30 years with no problem using that technique.
It's going to be extremely hard to do that with battery cables! - pcmentor29ExplorerI wanted a joint that would not corrode with moisture which I think crimp joints would. For my Toyota Motorhome there are 5 or so such joints under the intake which I have soldered since. I may re-solder them at some point because now I know to scrape the wire and use rosin flux by brush before I tin them. Thanks for all the help.
That would be when Morse Code over the telegraph became obsolete ;)
Can you tell old triceratops here when they changed the name from "Western Union Splice" to "Lineman's Splice"?- MEXICOWANDERERExplorerBismuth solder melts at a lower temp than 360, as does SN 63, but electronic techs seem to get a little cranky when you toss them a roll of 40/60 .090" Kester.
Wisdom comes with age and experience. People who cannot solder nor find technicians who can solder will stand on their head trying to convince people crimping is better. I have to laugh when these serious faced folks discover much too rudely for their taste that one of the worst environments on the face of the earth for vibration, a diesel engine, uses a starter motor and alternator with dozens and dozens of soldered connections. Heck, some voltage regulators must have hundreds of wave soldered connections. Industries prohibit soldering solely to cover their rear. They make it code. They make it holy writ. They cannot find people who know how to solder. SIXTY years ago my mother got a job at SYSTRON DONNER, because she, one out of forty applicants, had the talent to solder electrical junctions correctly. But the argument will continue, and I will keep smiling - the guy in the checkerboard suit and paisley tie will continue to sell chainsaws in the Sahara. - GdetrailerExplorer III
I hear the argument "SOLDER MELTS AT 360 DEGREES! WHAT GOOD IS THAT?"
Trust me, if a wire temperature soars to 360 degrees, you'll be busy elsewhere than with whether the solder has become soft.
Acutally there are lots of different melting points for solder depending on the usage so really no on temperature "fits" all applications.
I would tend to agree with your statement, in fact MOST insulation will start to fail around that same temperature so if you have a wire hot enough to melt solder the insulation WILL be near failing :E
I personally would not want to be in that situation...
I get a kick out of this forum, my Tech school taught that soldering connections were the best mechanical and electrical connections.
Followed that advice for nearly 25 yrs without any problems, then sign up to this forum only to find out from many experts here that I have been doing it all wrong all these years :S
I guess that is why for many years I made money from repairing BAD CRIMP CONNECTIONS, fixing them by SOLDERING them :B
I will stick with soldering.. - MEXICOWANDERERExplorerCan you tell old triceratops here when they changed the name from "Western Union Splice" to "Lineman's Splice"?
- wa8yxmExplorer IIIAlas. I do not have to ask how you know that.... After all, WE know that, and quite likely learned the same way.
- Canadian_RainbiExplorerSoldering done correctly will have a good mechanical connection first even if it is just a linesman's splice. Then use heatshrink to weather proof it. Don't forget to slide the tubing over one of the wires first. Don't ask me how I know that. :S
the air for almost 30 years with no problem using that technique. - MEXICOWANDERERExplorerI hear the argument "SOLDER MELTS AT 360 DEGREES! WHAT GOOD IS THAT?"
Having RV issues? Connect with others who have been in your shoes.24,312 PostsLatest Activity: Sep 06, 2025
