wolfe10
Feb 04, 2018Explorer
What inverter are you installing?
Very much doubt that you would want to switch the large-gauge feed from the battery. Most have an on-off switch on the inverter.
Some have built-in transfer switch (often called "pass through"). If not, then, yes you will need a separate ATS or manual switch.
You will be separating out both hot and neutral for those outlets.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
