BFL13
Feb 04, 2018Explorer II
Some 1000w inverters have remote on/off switches but you have to find a route for the remote's wire to where you mount the switch. Doesn't the cabinet the inverter will be in have a door? (it will need good air venting to keep the inverter cool)
Powering only the receptacles can be achieved easily if the converter is not on that same 120v circuit like it often is. So first remove the converter from that circuit somehow. Give it a different breaker on the AC panel or else give it its own switch on the converter's black wire to the breaker it shares with the receptacles' circuit.
Next is the television that is plugged into a receptacle. When it is turned off it is still on in standby, so plug it and the dvd player into a power bar that has its own switch and plug that into the receptacle. Now you can kill the TV while using other receptacles.
You can just plug your shore power cable via adapters to the inverter's receptacle to get the receptacles to go live. If you don't want the microwave to be used, or other circuits, just turn off their breakers. You don't have to do it all with transfer switches and sub-panels etc. Put the fridge and water heater on propane.
The draw from an inverter on standby is fairly trivial depending on the camping scenario/situation so you could just leave it on, depending.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
