pianotuna
Feb 04, 2018Nomad III
I'd suggest two inverters. One for charging laptops and below PSW in the 300 watt region so an electric heating blanket may be used, and a 2000 watt Prowatt from Best Converter (still in the "throw away" class) for powering all the outlets. Move the fridge and converter to a sub panel for the 120 volt shore power.
Or you can use male and female plugs as I chose to do. It makes it an "easy" way to change, in my case, because access for the power distribution box and breakers is under the bed.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
