dougrainer
Mar 21, 2018Nomad
According to the wiring Schematic, there is a FUSE between the 12 volt element and the tstat 12 volt output. You need to check for 12 volts at the OUTPUT of the tstat. If you have 12 volts, then that fuse is the problem. Since it is so old, I have no idea where Dometic located that fuse, but it is between the tstat and the 12 volt element. Doug
It is a 25 amp dc fuse.
