neschultz
Mar 21, 2018Explorer
obscenic wrote:
Thanks everyone for the thoughts!
Neschultz; there's 12v at all time. My domestic battery is actually completely isolated from my vehicle battery; the alternator does not charge the domestic battery.
I wasn’t clear enough. The 12 volts from the alternator to the refer did not operate the refer or charge it. It was a logic voltage that allowed the use of the TT 12 volts to operate the refer. It probably operated a relay. The refer would also not run on 12 volts automatically...you had to manually select it. When the engine stopped, it would revert back to AC or LP automatically.
