SlowBro's avatar
SlowBro
Explorer III
Mar 24, 2022
[SOLVED] Bad converter? Low voltage
The voltage in our class A's converter drops as low as 8.2V (measured with a cigarette lighter voltmeter) with a DC laptop adapter attached. Causes the charger to stop and the laptop not to charge. It currently has no house battery connected, though there is a starter battery. After some time the laptop charger stops trying and the voltage stabilizes at 10.9V. Is this a sign of a bad converter, or is this because no house battery is attached?
  • Verify the low voltage right at the converter output. Once confirmed then replace. Yes virtually all newer converters are made to operate fine without a battery.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Which converter do you have. Most of the newer converters don't have to have a battery attached, but some of the older ones do require a battery.
    However, the converter voltage should be above 13.2v under all conditions, so it very well could be a bad converter.
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
