SlowBro's avatar
SlowBro
Explorer III
Jan 03, 2021
[SOLVED] Can an inverter on a car charge the house battery?
I've got a 2006 Toyota Sienna with a 150 amp alternator and the RV converter is 45A. Battery is a group 24 lead acid. I want to know is it feasible to charge the house battery using an 800W inverter from the Sienna to the converter and a 15A adapter? I don't want to strain the alternator.
Ideally I'd install solar but this is for occasional recharges, not daily.
Edit: Solved this. Even my cheap inefficient Chinese generator only uses about $12 in gas to run for six hours, so I will prefer that. But the inverter uses about as much current as idling with the A/C on, headlights, and radio, so it should be safe for occasional use this way.
  • Where oh where did you get the silly notion that the alternator doesn't charge batteries?
  • I do also have a 6A car battery charger.
    The inverter to converter makes the most sense, if it won't burn up the alternator. But I'm finding the charge rate of the converter may require a lot of hours of car idling. I guesstimate 6 hours on charging from 50%.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
