Chris_Bryant
Jun 02, 2017Explorer II
You have a 12 volt problem- nothing to do with 120 vac. The thermostat most likely gets power from the furnace, so if you sort the furnace problem out, all will be fine.
The 2 amp fuse is in the thermostat, fwiw.
