drsteve
Jun 02, 2017Explorer
rejestered wrote:
However, I noticed that the furnace circuit itself is getting only 0.2V. I verified this with a multimeter by putting both red & black connectors into the slot where the 15A fuse goes.
That's not how you do it... check the voltage by touching the red probe to the hot side of the fuse and the black one to ground. You are simply placing the meter in series with whatever load is present on the circuit. This doesn't measure the voltage.
