rejesterd
Jun 03, 2017Explorer
drsteve wrote:
The furnace blower is supposed to continue to run after the thermostat shuts off the burner, until the heat exchanger cools off. Does it shut off immediately now? Because it shouldn't.
You probably need to reconnect the wire to where it was.
No, it takes the expected 2 minutes for the blower to fully shut off after the heat cuts out. Before, I waited at least 4 minutes and it was still going. So everything looks good.
