rejesterd
Jun 03, 2017Explorer
Edit: After learning a bit more about the wiring, I do think that moving the yellow wire was necessary.
Replacing the thermostat fuse definitely solved the original problem of the AC & fan not working. What caused the fuse to blow in the first place is still unknown.
Once the thermostat was working again, I then discovered the additional issue with the blower not cutting out after 2 minutes. That issue was solved by moving the yellow ground wire (for the relay) to a different connection on the furnace housing. So the other ground connection must have been too corroded.
