Harvard
Nov 06, 2016Explorer
That housing contains the thermal spring for setting the choke based on the temperature.
In my case, this thermal spring goes to a full hot position when the gen warms up to operating temperature AND THEN HANGS UP there. So during the next cold start cycle the choke is stuck in the full open (non choke) position and the gen set will not fire up.
I have fiddled with this for years to no avail. So, I have just gotten used to manually dislodging the stuck spring when cold so I have some choke applied before I try to crank it over.
I too will be very interested if someone knows the secret to this problem.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
