CloudDriver
Nov 07, 2016Explorer
Snowman, Since you asked for a picture, here is one I took a few years ago for a post. The setting of the disc is about the same as yours and is as set by the factory since I have never made any adjustments or taken it apart. Our RV is in the driveway, so I went out to take a fresh look. Still the same as the picture. I moved the rod from the choke end and noticed no binding. I did notice that when I pull the rod toward the choke the rod moves from the center to the top of the hole. From your picture, the rod is at the top of the hole when cold. Just a guess, but perhaps that is the cause of the binding.
In case it helps, here's a picture of the choke end that shows both a side view and a reflected top view in an inspection mirror.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
