KendallP
Jul 29, 2016Explorer
haddy1 wrote:
That sure sounds like a vacuum leak to me. While hoses are the easiest to diagnose, there is also a good possibility that it is an intake gasket or carb/TB base gasket. I would try spraying WD40 on every gasket surface to see if you can isolate the sound (pitch should change if you spray the leak) and check all of the intake manifold bolts.
THANK YOU!!!
Sure does to me too.
My old man mentioned carb gasket yesterday, as a matter of fact.
WD40 it is!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
