KendallP's avatar
KendallP
SOLVED!!! Loud Screech from the 454!!!
***EDIT***
Note 1: I believe all videos posted below are a must-view before comment...
Note 2: Belts reinstalled now since they nor the components they run are the culprit.
I picked up the Winnebago from the storage yard yesterday afternoon. Of course I warmed 'er up a bit and then off I went. About a mile or so down the road, I began to hear a bit of a whine. Within another mile or so it became a loud screech... almost a vibrating metal on metal sound.
My first instinct was vacuum because in my mind, the most interesting part of this phenomenon is that it completely disappears for an instant when I stomp on the gas. In that moment, RPMs are changed only slightly. This occurs without fail every time and often more pronounced than my video. See link below...
I removed all belts. Screech still there. Finished up around 10 last night.
Mexicowanderer recommended next I Vice Grip pinch the small hose coming out of the "protrusion" off of the smog pump. So this morning I got up and did that. Then starter 'er up. No noise. Great!
Then I removed the Vice Grips. Still no noise. Dang.
I wish I had starter 'er up first.
So now I'm left to wonder whether the pinch did something or if this only occurs when she's warmed up.
I plan to put 'er back together and warm 'er up with the water pump running again to see if the noise comes back. If so, then I will retry the pinch.
Any thoughts?
Note the noise disappearing for the instant I stomp on the gas...
https://www.youtube.com/watch?v=Rq5XvVMwMVc
New videos...
https://www.youtube.com/watch?v=ImTWQeb8jNE
Upon shutting 'er down after the video above, I noticed another sign. So I starter 'er up again for the following video. Silence until I gave her just a little gas. Then a few more pedal stomps and shudder' down (that's Jefferson State speak for, "Turned the ignition switch to the 'off' position."...
https://www.youtube.com/watch?v=klk4B7nHsjI
  • It's coming to haunt you...
    It was intermittent to begin with. Why do you wonder that it does not appear and disappear on command of a pair of Vice Grips (or not)?
    Reassemble and DRIVE THE RIG with this small hose PULLED OFF and a sheet metal screw blocking off the uncoupled hose.
    I was forced to diagnose this krap when customers gave orders for a new alternator, and I knew the WHISTLE to be emanating from the Air Injection Reaction Pump. GM's had this setup for years - the AIR pump nestles just below the alternator. I always had Armando pull all the belts just as you did and found many a flaky water pump bushing, weeping power steering pump or hose and noisy AC clutch bearing.
  • Hard to turn Alternator
    Bad Fan Clutch - hard to turn
    Same for water pump
    The above will cause a screech at low RPMs which may go away when you hit the throttle.
    Oil Pan dented
