enblethen
Aug 12, 2015Nomad
Have you checked the inside of the distributor cap for wear and electrical tracking?
Is this a coil mounted on the distributor cap? If so the contact between coil and cap could be worn out. Distributor cap if like this you need to check the center point.
Remote coil? check for a crack tracking on high voltage lead along backlight. This is on some later models.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
