Fishinghat
Aug 12, 2015Explorer II
darsben wrote:
If the distributor cap is arcing then spark would show but maybe at the wrong plug at the wrong time.
I would try new Distributor cap and rotor as the first thing.
When you do diagnose please post the cure to add to my knowledge base as I have the same motor
This would also be my recommendation. It's easy, cheap and there is a strong possibility the cause of your problem. If not, you've eliminated a possible contribution to the problem and you can focus on timing, stuck float level, failed fuel pump, clogged fuel filter, and so on. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
