KendallP
Aug 13, 2015Explorer
enblethen wrote:
...If you have an Ohm meter check the resistance of the coil.
Between white and pink going into the coil should read less then an Ohm.
Between the rotor button and the bat terminal(pink) should be between 6000-30,000 ohms.
Roger that
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
