KendallP
Aug 25, 2015Explorer
MEXICOWANDERER wrote:
...You didn't have to change the relationship between crankshaft and camshaft orientation did you? Merely ignition timing to the rest of the world.
Yes. All I did, initially, was to adjust the distributor and she fired right up... and seemed to run as she always did... for several days of short hauls and then several hours of long haul before things got ugly.
I had thought a single tooth skip may not cause such havoc as I had heard of hot rodders advancing cam timing on purpose.
Sounds like I was mistaken.
So...
with the distributor showing zero physical signs of issue and rotating by hand beautifully..... what the heck happened???
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
