MEXICOWANDERER
Aug 25, 2015Explorer
CLAMP DISTRIBUTOR GEAR IN VICE. Use giant crescent wrench to try and turn top of shaft. Cam gear is cast into camshaft. This should not turn into a Hitchcock grade thriller. Yes there is another shaft stage in some HEI distributors. Find the problem, fix it and go camping.
99.99999999999% of the GM roll pins I saw sheared, were not visible shears. Your hands are WEAK compared to the power demanded spinning an oil pump.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
