KendallP
Aug 28, 2015Explorer
Checked the vacuum advance with some negative lung pressure. Got it to come out quite a ways. Then it snapped right back once I let off. Seems ok.
OK. I torqued on the distributor gear. Had channel locks on the upper portion of the shaft... underneath the mechanical advance.
Didn't put 700 ft lbs on it or whatever, but a fair amount. Then I got a little paranoid that I was stressing the mechanical advance. Is that correct? Are those little weights the only things keeping the shaft from reversing? If not... then what is?
Clearly the shaft is not a single piece between the gear and the upper portion that's below the mechanical advance/rotor connection. Turning the rotor against the springs will also turn the upper, visible portion of the shaft, but not the gear down below. Was not expecting that.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
