Salvo
Sep 04, 2015Explorer
I haven't followed all the discussion, but there's some chatter about the timing chain perhaps being off. Can't you test for that scenario? Rotate engine to get piston #1 to TDC (first remove plugs, but keep them connected & grounded). The distributor should now be in position to fire plug #1. Do you see that plug spark? Do you see the other plugs spark in the correct order? You should be able to rotate the engine by putting a wrench on the crank pulley. Make sure you turn it the correct direction. Perhaps clockwise when looking from front.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
