Salvo
Sep 04, 2015Explorer
What is the overriding reason to replace the distributor? How can the distributor slip? Are we talking about the slip collar and the hold down bolt to adjust the timing?
Again, I would remove all plugs and rotate pulley so piston 1 is at TDC. This should coincide with the rotor making connection to plug 1 and the pulley notch aligns with the timing mark.
It shouldn't be that hard to rotate engine with plugs out. You can watch the plugs spark and then verify piston is at its high point. Some 50 years ago I used to time motorcycles from the position of the piston.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
