KendallP
Sep 21, 2015Explorer
I godda' wunna' deez, mane.
Photo of actual unit in that post. Together we determined it's a 12SI.
I have a rebuilder I trust. Says he can update it to a 94A for no more than $100 depending on how bad a' shape the core is in.
Otherwise I'm considering a CS-144, but I first need to verify that...
A. It will fit (radiator hose clearance and a bracket that I can shim)
B. The V-Belt that runs it doesn't also run the smog pump or anything else. There are a lot of belts in there, so it may be running solo. I could tell you right now, but... since it runs now... it's parked on the other side of town.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
