MEXICOWANDERER
Mar 18, 2016Explorer
330% increase in tractive ability with the serpentine 5-rib. Here's one:
6-71 Detroit running an alternator off the blower drive. Commercial salmon boat. When trolling, engine is running about 1200 RPM. Blower drive is 50% of that. Limited budget, no $3,000 8-9/16" Leece Neville alternators. Batteries discharging 40+ amps. Front pulley on engine absolutely inaccessible.
Oh what do you do? Failure is not an option
Use a MoPar 4091460 alternator. Pulley pressed on not bolted. .670" 17mm shaft. Allows room for a 1-1/4" GILMER BELT PULLEY. Chose 5/8" shaft and bored .625" to .669"
Purchased 7" GILMER BELT pulley for blower drive. The absolute maximum diameter that would fit.
Math 560% overdrive ratio
1200 X 5.6 = 6,700 RPM
550 RPM idle X 5.6
120 Amperes at troll
108 amperes at dead slow idle.
Total parts cost $388
I had free King splitter fillets for two seasons. We won't talk about the Shakers.
Sentence above is harborspeak.
With knowledge the world is an easier place to work in.
550 RPM idle X 5.6
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
