time2roll
May 24, 2018Nomad
Jetstreamer wrote:Actually the PD converter is probably operating as designed. The batteries were a bit low so the PD charges up to 4 hours at 14.4 volts and very close to max amp rating. This is something the WFCO probably never did as WFCO is notorious for NEVER going to boost mode at 14.4 volts. This is why a 40 or 50 amp self resetting breaker has no trouble with a 55 amp WFCO... they just trickle charge at 13.6 volts.
Maybe it was some sort of overload due to low battery... what should I be seeing as far as lights on that charge wizard for normal automatic operation?
Ok on edit I did review the owners manual for proper operation with the remote pendant...probably too high of a charge... I’ll keep an eye on it..
I assume you have a 60 to 80 amp PD and should have installed #4 wire and a 100 amp breaker near the battery and really get your charge on. BTW those self resetting breakers are very unreliable. I recommend Bussmann Hi-Amp (amazon).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
