Artum_Snowbird
May 24, 2018Explorer
The most notorious reason for a high load is a loose connection. That loose connection causes a huge resistance in the circuit. What used to run fine under a ten amp fuse now wants 20 amps. The connection heats up and corrodes some more, burning the wires.
Take a good negative to the load. If that fixes it, look at the negative line back to the battery. Same with the positive side.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
