SoundGuy
Jun 20, 2018Explorer
buylow12 wrote:
It's a 2004 RM2652 as best I can tell the manual is for either of them and doesn't explain the difference, I assume one is larger than the other.
2652 is a 6 cu ft fridge, 2852 is an 8 cu ft. So your particular fridge has the switch but perhaps it's failed and is not disconnecting power to the heating element. Cut the heavier red wire that runs to the interior light switch ... if power draw drops then you'll know for sure.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
