MrWizard
Nov 26, 2013Moderator
Mex... check here..
maybe this one ?
SEN-08630 RoHS Compliant. This is a simple to use motion sensor. Power it up and wait 1-2 seconds for the sensor to get a snapshot of the still room. If anything moves after that period, the alarm pin will go low.
This unit works great from 5 to 12V (specsheet shows 12V). You can also install a jumper wire past the 5V regulator on board to make this unit work at 3.3V. Sensor uses 1.6mA @ 3.3V.
pir motion sensor
maybe this one ?
pir motion sensor
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
