- Sam_SpadeExplorer
Gjac wrote:
It took me longer to remove it than to clean it. It was rusted on good and I needed a propane torch to remove it.
You are helping to make my point. You got lucky with removing it.
What often happens is that the "pipe" that is screwed into the head breaks off and then you have a real mess.
A little carbon buildup in a muffler is NOT a problem....really.
Even more than a little usually is not a problem.
If it bothers you, once it's good and hot give it a few taps with a hammer handle or screwdriver handle while it's running at speed. Any carbon that is loose should come flying out. If rusty metal pieces come flying out.....it's time for a new one. - GjacExplorer III
Sam Spade wrote:
The spark arrester on my genset which is 20 years old. I cleaned it once and the screen was black but not clogged with carbon. I soaked it in gas over night and blew it out with compressed air. It took me longer to remove it than to clean it. It was rusted on good and I needed a propane torch to remove it.
Unless and until the carbon accumulates to a point that it makes a significant restriction to the gas flow......they don't need to be cleaned. The hot fast gasses flowing through should be enough to keep the passages open. The carbon that might accumulate on the flat surfaces should not cause any problem until it gets REALLY bad.
AND....if the engine makes enough carbon to plug the muffler/spark arrestor quickly then you likely have something wrong with the engine. 2-cycle engines are bad about that; others should not be. - eHoeflerExplorer IICarburetor cleaner
- RLS7201Explorer II
VTR wrote:
Wire brush and blow torch to clean these things. Is there some liquid I can put them in that will eat away the carbon? Need to buy some replacements but still trying to find them
That's the method we used, when racing 2 stroke dirt bikes. Never found any thing better.
Richard - Sam_SpadeExplorerUnless and until the carbon accumulates to a point that it makes a significant restriction to the gas flow......they don't need to be cleaned. The hot fast gasses flowing through should be enough to keep the passages open. The carbon that might accumulate on the flat surfaces should not cause any problem until it gets REALLY bad.
