Harvard
Jun 09, 2013Explorer
rkentzel wrote:
You need a meter an check voltage to the coils ohm out the coils on the valve. You already check the obvious now you need to work backwards with a meter to check voltages. since it sparks and no gas you cold have an open coil on the valve
X2...it is usually the coil closest to the tank that fails open, probably because of the heat cycling from the tank.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
