harmanrk
Jul 26, 2013Explorer
eb145 wrote:
I crawled under my trailer and found the manufacturer's name and part numbers stamped on the grey and black tanks. They were identical tanks - same manufacturer and part numbers stamped on them. When I checked the tank manufacturers web site, the tanks were listed as 5 or 10 gallons less than the specs listed by the trailer manufacturer.
The trailer manufacturers seem to have fine print about "specs may change without notice"...
Ed
Not always. My black water tank has the three inch pipe that runs about 5 feet, to a valve. Now when I start using the potty, the first fluids in, do nott magically set in the tank, but travel all the way to that valve. I would not think 5 gallons of water in that pipe would be too far from the mark. Now solids, those will pretty much set on the bottom of the tank, until the pipe is full, and the tank itself begins to fill.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
