afinepoint's avatar
afinepoint
Spec for black water tank is 34 gal yet 21 fills it???
The volumes for the black and grey water tanks in the RPM TH are 34 gallons each. When filling and flushing the black water tank I realized that after about 21 gallons water stood in the bowl and wouldn't drain. It happened twice. Also after about 15 gallons or so the toilet would begin "belching" air into the bowl as I tried to flush. Opening the ball valve less didn't help. Although it did seem if I waited several minutes before flushing the bubbling was not as violent.
I checked the roof vents for obstructions since the system acts like it can't vent properly.
Was I misinformed about the tank sizes?
Reg
  • You don't say if the unit is new or used. If new take it back and have them check the tank for obstructions. If used, then there may be stuff left over from the previous owner and you may need to clean it out. There are several threads on this topic.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
